Originally Posted By: jpeck
| dfrend wrote: |
| A license might improve our image, agreed. But setting a level that would be impossible for new inspectors to reach because of lack of opportunities would shut them out and would be a disservice to the consumer. When the supply of licensed inspectors exceeds the demand, the consumer is hurt. |
That's why that is covered.
Should you (maybe I should say 'do you NEED' to) know codes when doing a regular re-sale home inspection?
Well, of course, it is beneficial to you, but do you really NEED to know them? No, but you should have some understanding of them, after all, codes are what the house is (supposed to be) built to, so to know what is wrong, you need to understand what is right).
Now, another subject matter.
Should you (i.e., 'do you NEED' to) know codes when doing NEW construction home inspections? You better, if not, you are providing your client with less than an adequate inspection, after all, the house was (should have been) built to codes as a minimum, and getting that minimum (and more) is not possible if you do not know that minimum. Code is a minimum, and there is no reason to accept less - where codes are adopted (and in Florida there is now ONE code and it is in effect statewide), the code is the legally enforceable MINIMUM builders are allowed to get away with. So, to do your client justice, you need to know codes.
Why force a new inspector to learn codes for resale inspections when they are not needed (I still think they are NEEDED, but I will give that to those who argue that codes are not needed on resales - who said I wasn't nice, huh?)?
So, we have two levels of certified inspectors. Like with contractors (there are really three levels of contractors). The residential contractor can only build one and two family residences three stories and less in height. There are reasons for that.
Thus, the new inspector would be able to do resale residential inspections without knowing anything about codes. A nice way to be able to break in easy.
The top level of contractor, the General Contractor, is allowed to build anything as high as desired (within zoning limits and engineering limits).
The top level of inspector would also be able to inspect anything, including new construction, because they have greater knowledge and experience.
Not all Residential Contractors even want to become General Contractors, they will never build more than they are, for their own reasons.
Just like not all home inspectors will want to, or feel the need to, learn codes and become the 'General Contractor' of inspectors. But they all CAN, IF THEY WANT TO.
Jerry Peck
South Florida
